I have a Taz 6 that’s experiencing issues.
Recently we had to switch to a HS .8mm tool head because we sheared a brass nozzle in the stock tool head and couldn’t get it out. I tried printing out a rocktopus to see if the it printed right, the nozzle was smearing the pla bead and the print came out crappy.
After more digging, I realized I had to update the firmware to the printer. I added printer TAZ 6 HS .8mm and updated the firmware in Cura. Now when I attempt to auto home the printer, instead of hitting the home button on the bed, it hits the stainless steel disk at the top left corner of the bed.
Is there a way to manually zero the bed or should I just re flash the firmware update?
Thank you
