Hi all,
I have 2 Taz 6 printers and a Mini here at work and over time the “Print from SD” menu has gotten incredibly slow and laggy on all of these printers. I turn the knob a click or two and it takes maybe 1-3 seconds before it actually scrolls down. It is also very difficult to select the right file because of this.
Any idea what has caused this and what I can do to fix it? I was surprised that I didn’t see this topic anywhere on the forums when I searched, especially because it has happened on all 3 of our printers.
Any help is appreciated!
Thanks.
Hello,
When the LCD starts to react a bit sluggish when going through the SD card, it is usually a sign that it is a bit too full.
I would recommend saving whatever files you have on your SD card that you want to save and formatting it to FAT32 to remove any older unnecessary files. Then load just a couple models onto it and see how it reacts.
Aha! This worked! What an easy fix, thank you so much.
I put the old files in a subdirectory so lulzbot doesn’t see them.
I probably will never use those files again but it’s still nice to have the names around as a reminder of which .stl file to send to cura. Since I use different materials I’d never reuse the final print files anyway.
