Taz 6 Rotary Encoder not Scrolling
Hello, I have a Lolzbot Taz 6, fitted with a dual extruder V3.0 tool head and updated with the newest firmware 1.1.9.34.
Before the update, the rotary encoder on the LCD board stopped scrolling through menu items!
Thought it was the encoder at fault, so purchased a new RepRapDiscount Full Graphics board. Made no difference.
I have tested the encoder, and the square wave appears to be fine out of the encoder, when rotated. This signal is also making it’s way to the 2560 processor, at pin 68 and 69.
But still no matter what I do I’m unable to get the menu to scroll. Cables are fine, and in the correct orientation.
So I can only assume it is either a RAMBO board or the Firmware setup at fault here, not sure. The printer works fine controlled via USB, so I’m not sure if it is the RAMBO. I really do not want to purchase a new RAMBO V1.4a and find out that it is not at fault.
Anyone have any idea what could be causing this issue, thanking you in advance.
Cheers Asho
Reach out to the support team at https://LulzBot.com/Support and they’ll be able to help troubleshoot this. Does the encoder work when you flash the standard single extruder tool head firmware?
Thanks Orias,
I have been in many different forums and videos trying to diagnose this issue, but yet to find an answer that fixes the issue.
Also I have been to support, and chatted with Nathan there. Although Nathan was helpful in trying to sort the issue out, he and I’m assuming Lolzbot Support are unable to work out what is causing my issue.
So I thought I would come here to see if other or one other person had this issue!
The issue started when the single extruder was fitted, and the initial firmware was loaded. I had hoped that by changing the hardware and then of course updating the firmware, that it would have fixed this issue.
I have even sent a request to the manufacturer of the RAMBO board, but yet to receive anything back from them as yet!
So as I have already replaced the LCD board including the rotary encoder, and this did not fix the problem. I’m a little hesitant to just replace the RAMBO, still thinking that it maybe still in the firmware that my fix resides.
Thank you again Orias for your suggestion, but I will keep on trying to find the exact cause, short of replacing the RAMBO. Then I will get back to this post with the fix. Not that anyone else has had this problem, but maybe it may help just one Lolzbot customer!
