Taz 6 Button Wheel Unresponsive and Clicking Itself
Hello,
I’m having a couple likely related problems with my Taz 6. The first is that the button wheel on the Taz 6 stops responding after the printer has been going for a while. Usually it works after a hard reset, then after I print something it stops working, or is very unresponsive.
The other issue is that now occasionally when it prints it will act as if it’s pressing the button repeatedly. The LCD screen switches and the printer beeps as if the button is being repeatedly pressed. Pressing the button temporarily stops this behavior but it comes back right away. Here’s a video of what I mean:
I’ve tried upgrading firmware and am about to switch back to the normal extruder (I normally use the dual extruder v3).
Thanks,
-Donnie
It sounds like the button on the rotary encoder is stuck/intermittent. Have you tried reaching out to support? I believe it’s this part according to the BOM: EC11E15244B2
https://www.onlinecomponents.com/alps-electric/ec11e15244b2-10113566.html
I haven’t yet, but I’ll reach out to support-- thanks for finding the part!
Hey did you ever find the solution? I just found out that I have the same problem with mine.
While it may seem like an issue with the LCD itself, we have seen that this is usually an issue with the control board itself unfortunately.
