I am using the dual extruder and when I do a print that will only use one of the extruders the printer simply heats up and starts printing wherever it is. It doesn’t home any of the axes or clean the heads, or auto level. When I do a print with both heads then it does all of these steps.
I am using Cura Lulzbot edition version 19.12.
I am not running any custom g code or anything, just a simple standard run.
Is there any way that I can fix this?
I like the dual head extruder, but sometimes I just want to use one of the heads, and I dont want to have to switch out heads and re calibrate every time I do that.
