Hi,
Just got my HS+ 1.2mm nozle only my TAZ 6. Did the following:
Selected the correct toolhead in the menu of the machine
changed nozle size in CURALE
set layer height at .8, 2 walls 2 top and bottom
Speed is about 45mm/s
Upon starting a print the extruder will bounce between 204 and 2018 when trying to hit 210 temp. It will literally overshoot and then undershoot maybe 10 times? for about 4 or 5 minutes…
First layer seems to go down - permiters look good, then upon filling the floor it starts to look a little over-extrudy. Made it up to maybe 4 layers or so the print usually starts to fail. Seems as though the PLA is just not sticking to the layer below it.
I thought maybe my z offset is too low - so the first layer is super low and at .8 jumps it actually just jumps a little too high for the 3rd or 4th layer to stick?
Does anyone have any advise with the 1.2 nozzle? Is there a CuraLE slicer setting out there?
