Does anyone know what connector is used for the Control Box power harness? It’s the part described in step 3 of the Control Box build here https://ohai.lulzbot.com/project/c8d1632e-5df4-4844-8f4f-e653379a8fc3/a16b1f2d-5c1f-47fe-a83d-9d68cca5d62c/
The docs for the CB power harness show it being built, but dont identify what the 4 pin connector’s ID is:
http://devel.lulzbot.com/TAZ/Guava/production_parts/Electronics/CTRL%20BOX%20-%20Internal%20Harnesses/Harnesses/CB_%20Power%20Harness%201.1.odg
Thanks in advance.
Wrong connector - have not found it yet.
A25053-ND at Digikey according to the Juniper BOM.
I tried that part, and you can see from the part image (for example http://www.digikey.com/product-detail/en/211102-1/A25053-ND/292445) that it doesn’t match the one used in their power harness (https://ohai.lulzbot.com/media/uploads/CB4.jpg.600x0_q85.jpg). I believe A23053-ND is used for the heat bed harness (https://ohai.lulzbot.com/media/uploads/IMG_0472_1.JPG.600x0_q85.jpg). I can’t find any other appropriate 4-pin connectors for the power harness in the BOM. Its also worth noting that the power harness plug is much larger than the 4-pin connectors used in the rest of the harnesses.
jschvey
5
Here you go: > http://i-t-w.com/parts/?category=Cables
Perfect, thanks!
Incase anyone else is looking, I ended up finding it in in the Power Supply BOM (https://devel.lulzbot.com/TAZ/accessories/Pomfret/production_docs/Power_supply_BOM.ods). WEIPU SP2112/P41N which looks to be a huge pain to try and source.
Really glad it was posted for sale on ITW, saved me a lot of trouble.
