These are straight off the waterjet (raw finish) so will be some scuffs or scratches on the plate. They can definitely be polished, although I don’t know why you would do that considering this part isn’t really visible…
Anyway, I paid about $35 per plate with shipping, looking for $45 to pay for the time to ship them. PM me if interested!
I just read through rsilvers’ BOM and I lament my failure to post this earlier…
I just want to post a rave about http://www.boltdepot.com. I ordered (almost) all of my TAZ hardware from them as opposed to buying bags of 100 or whatever from McMaster; yes, they sell individual pieces at a very reasonable (sometimes better) price! Although there is nothing wrong with having leftover hardware…
The black oil finish they offer is much like black oxide, but with a more metallic, oily sheen to it. It has different mechanical properties, but the difference shouldn’t affect this build. It looks great, and I think I actually prefer it to black oxide.
Going with ACME screws and nuts on the Z-axis is WAY overkill. ACME is great if you have tons of weight to move, that is the reason it was designed (superior thread strength, and easier to rotate under large loads). If you have a hundred pound spindle to move, yes ACME is the way to go. But for a 10 to 20 pound X axis carriage on a 3D printer it is not worth the extra cost and complexity. I am sticking with the standard M8 all-thread and nuts.
Backlash in the screw is not as big of a deal either because you have very little Z-force trying to push the carriage up when you are extruding from a tiny nozzle. not like on a milling machine where there is a lot of force pushing back up like when you are drilling metal.
The weight of the X carriage assembly on a 3D printer will always be many more times that of the force from the pressure created from extruding the plastic, so simply relying on the weight to remove the backlash is perfectly fine.
The higher efficiency of ACME is probably not needed since there is no heavy weight to add lots of resistance. But standard threaded rod is not designed to have minimum wobble or be straight - it is designed to be cheap, as it is usually used for hanging air-conditioner ducts, and price matters way more than precision - so they thread-roll them.
The ACME I ordered, while I am not sure that it is ground, was at least selected for linear-motion applications, and is more likely straight and concentric. Also the ends are reduced for coupling and so you don’t need to grab on the pointy-threads - which are not necessarily concentric with the thread-pitch diameter. And finally it has a nice large base to the nut which is going to be more perpendicular to the threads once installed.
The cost is only $19 more, assuming you had to buy a whole bag of brass nuts as I would have.
We haven’t gotten much from Bolt Depot, but I have been to their site and considered them. For our next batch, we got a lot of the vitamins from Timberline instead of McMaster. Timberline is local to us in Colorado, and was less expensive overall. That said, McMcaster is an excellent vendor and very very reliable and fast.
Both my current and former employers (small manufacturers) order from McMaster. It is an incredibly efficient company offering thousands of products. Their product catalog has more than 2 thousand pages.
The advantage of McMaster is it’s a one-stop shopping place. For shops and manufacturers it can be interesting because they have everything, no need to open multiple accounts at multiple places. But it’s true they don’t have the best prices.
FreeCAD is free to install and open source. It can export to STEP.
I noticed a problem with the jonaskuehling_gregs-wade-ao-v3.7.11.fcstd file. (you guys decided to model it in FreeCAD, cool! ) I intended to send an email to Seth about it but I have to go now, I’ll probably do tomorrow.
Oh, and a couple of files can’t be accessed. For example jonaskuehling_gregs-wade-ao-v3.1.3-idler.fcstd downloads an invalid file with a right-click, and when I left-click on it, I get a 403 forbidden page.
Yes, devel is the development server. Once the work there is considered complete I’m sure those files will be transfered to download.lulzbot and supercede the current files.
