Weird layers
Hey guys!
I am experiencing weird layers and I cant seem to figure out what is going on. it looks like the layers are too thin or the nozzle is too close to the bed?
What I have done:
used proper filament diameter
Played with flow settings between 90-110
calibrated e steps
printed with different layer heights .18-.25
I am at a loss. please take a look at the pictures I have provided. Thanks!
Your bed isn’t level in the prints. Looks like this is a mini, I would check the right corner washers for a loose washer, check the auto leveling wire for a loose connection ( its on the left so better signal on a loose connection might show up as an offset?) or loose wire on the nozzle. Its definitely your leveling is off though.
Also check that the heat sink on the Z driver chip has not came loose and fallen off.
