Can't set E steps on Mini 1
I just upgraded to Lulzbot Cura 3.6.4 (Ver 4 was not compatible with my mini) and went through all the steps. I recorded Z offset and E steps updated the firmware and reset the Z offset no problem. But when it comes to the E steps nothing happens.
I’m issuing the follow commands
M503
Stepper Motor currents
M907 X1300 Z1630 E1250
M92 E833
M500
Settings Stored
M503
and i get the same M907 X1300 Z1630 E1250
Shouldn’t the E1250 change to E833?
Old versions of Marlin used M503 to report steps/mm. Current versions use it to report the stepper motor current.
If you issue M92 without any parameters, you’ll get the saved steps/mm.
