hi to all, i found on kickstarter this project and I’m interested in their hotend. I contacted them through email to ask them if it’s compatible with TAZ4 but they answered that the new Lulzbots use the Hexagon hot end, which has a standard 16mm groove mount like the Hybrid. Can some please tell me if it’s compatible or not?
It has a standard J-head groove mount and to the best of my knowledge, that is the same as the Hexagon. However, you’r Taz 4 has a Budhashnozzle that has a very different mounting system. There are printable JHead mounts for TAZ printers on Thingiverse. The E3D-Online V6 TAZ mount should work fine.
Do you mean this? http://www.thingiverse.com/thing:372842
Exactly that one.
I had better luck mounting my E3D V6 using these parts. The E3D and Hexagon hotends are shorter that the Buda. The new extruder mount lowers everything a bit and the other parts let it all clamp together tightly while keeping the Z min end stop in range.
The groove mount body from:
http://www.thingiverse.com/thing:18379/#files
Adapter plate:
http://www.thingiverse.com/thing:220811
Extruder Mount:
http://devel.lulzbot.com/TAZ/Juniper/production_parts/printed_parts/extruder_mount_hex/
This adapter worked but I prefer the three parts listed above.
http://www.thingiverse.com/thing:374717
