My Mini 2 all of a sudden won’t communicate with my PC. It was printing fine yesterday, and was powered off overnight.
In the windows Device Manager I see it as
"Windows has stopped this device because it has reported problems. (Code 43)
A request for the USB device descriptor failed."
Cura LE 3.6.40 just says “no printer connected.”
Firmware on the printer is 2.0.9.0.17
Use a different USB cable.
Reboot the PC.
Boards going bad aren’t unheard of, but still fairly unlikely.
So far I’ve rebooted the PC, unplugged the printer and let it think about its life, completely uninstalled and reinstalled Cura via the suggestions in another thread, tried two different USB cables, different USB ports, and even tried adding a USB hub into the mix.
When I try plugging it into an OctoPrint it initially connects but once I try to print I get communication timeout errors.
kellbot
November 11, 2023, 3:48pm
4
Console output:
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyACM0, baudrate 250000
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0xa5851490, open=True>(port='/dev/ttyACM0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Recv: start
Recv: Marlin 2.0.9.0.17
Recv:
Recv: echo: Last Updated: 2021-06-15 | Author: Lulzbot
Recv: echo:Compiled: Oct 4 2023
Recv: echo: Free Memory: 1985 PlannerBufferBytes: 1440
Recv: echo:V83 stored settings retrieved (618 bytes; crc 2504)
Recv: Testing X connection... OK
Recv: Testing Y connection... OK
Recv: Testing Z connection... OK
Recv: Testing E connection... OK
Recv: echo:SD card ok
Recv: ok N0 P15 B3
Changing monitoring state from "Connecting" to "Operational"
Recv: ok N0 P15 B3
Recv: ok N0 P15 B3
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin FIRMWARE_VERSION:2.0.9.0.17 EXTRUDER_TYPE:Legacy-Series (Oct 4 2023 14:20:09) SOURCE_CODE_URL:https://gitlab.com/lulzbot3d/marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:LulzBot Mini 2 EXTRUDER_COUNT:1 UUID:e5502411-d46d-421d-ba3a-a20126d7930f
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:BINARY_FILE_TRANSFER:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_POS:0
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:RUNOUT:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:BUILD_PERCENT:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:1
Recv: Cap:HOST_ACTION_COMMANDS:1
Recv: Cap:PROMPT_SUPPORT:0
Recv: Cap:SDCARD:1
Recv: Cap:REPEAT:0
Recv: Cap:SD_WRITE:1
Recv: Cap:AUTOREPORT_SD_STATUS:1
Recv: Cap:LONG_FILENAME:1
Recv: Cap:THERMAL_PROTECTION:1
Recv: Cap:MOTION_MODES:0
Recv: Cap:ARCS:1
Recv: Cap:BABYSTEPPING:1
Recv: Cap:CHAMBER_TEMPERATURE:0
Recv: Cap:COOLER_TEMPERATURE:0
Recv: Cap:MEATPACK:0
Recv: ok N1 P15 B3
Send: M155 S2
Recv: ok P15 B3
Send: M27 S1
Recv: ok P15 B3
Recv: Not SD printing
Send: M20
Recv: Begin file list
Recv: /PRODUC~1/LABELS/MINI_V~1.GLA 182805
Recv: /PRODUC~1/LABELS/MINI_V~2.GLA 182805
Recv: /PRODUC~1/LABELS/MINI_V~3.GLA 684243
Recv: /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~1.GBR 52693
Recv: /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~2.GBR 1316
Recv: /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~3.GBR 504
Recv: /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~4.GBR 112543
Recv: /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~5.GBR 2728
Recv: /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~6.GBR 1617
Recv: /PRODUC~2/ELECTR~1/DOLORES/PCB_GE~1/Z_BRAK~7.GBR 35616
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.G1 597291
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.G2 792609
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.G3 276712
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GBL 751027
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GBO 151226
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GBS 25698
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GD1 559576
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GM1 2355
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GM2 7761
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GM3 4728
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~2.GM3 2267
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~3.GM3 2533
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GP1 41148
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTL 1233814
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTO 227592
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTP 65956
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0A/EINSY_~1.GTS 75364
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.G1 600702
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.G2 795243
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.G3 278203
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GBL 753079
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GBO 151203
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GBS 25690
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GD1 561128
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GM1 2348
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GM2 5625
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~2.GM2 7758
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GM3 4725
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~2.GM3 2261
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~3.GM3 2527
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GP1 41283
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTL 1229884
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTO 227808
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTP 66378
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/OUTPUT~1.0B/EINSY_~1.GTS 75786
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.G1 596727
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.G2 781847
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.G3 236734
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GBL 739066
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GBO 152446
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GBS 25156
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GD1 564729
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GM1 969
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GM2 5625
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~2.GM2 6443
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GM3 3413
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~2.GM3 924
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~3.GM3 1186
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GP1 41441
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTL 1097495
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTO 225154
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTP 65917
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/EINSY_~1/PROJEC~1/EINSYR~1.GTS 76056
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.G2 284845
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBL 267769
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBO 54687
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBP 1219
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GBS 9983
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GD1 131217
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GG1 63023
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GM2 2166
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GM8 195
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GP1 15236
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTL 401243
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTO 81259
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTP 26636
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~1.GTS 31314
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.G2 302082
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBL 282661
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBO 55799
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBP 761
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GBS 9718
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GD1 113608
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GG1 64676
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GM2 2122
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GM8 221
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GP1 15101
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTL 470203
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTO 83281
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTP 26878
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~2.GTS 31386
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.G2 302082
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBL 282661
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBO 55799
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBP 761
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GBS 9718
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GD1 113608
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GG1 64676
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GM2 2122
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GM8 221
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GP1 15101
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTL 470203
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTO 83185
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTP 26878
Recv: /PRODUC~2/ELECTR~1/EINSYR~1/BOARD/PROJEC~1/BOARDFAB/EINSYR~3.GTS 31386
Recv: /PRODUC~2/PRINTE~1/HEATSI~1/M2_PP-~1.GCO 1087374
Recv: /PRODUC~2/PRINTE~1/HEATSI~1/PP-GP0~1.GCO 1084911
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/LCD_MI~1/MINI/PP-GP0~1.GCO 3695513
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~1/MINI/PP-GP0~1.GCO 2000398
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/SIDE_C~1/MINI/PP-GP0~1.GCO 2998214
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/TOP_CA~1/MINI/PP-GP0~1.GCO 2120384
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/COVER_~1/M2_PP-~1.GCO 214510
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/COVER_~1/PP-GP0~1.GCO 212074
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/LCD_SP~1/MINI/PP-GP0~1.GCO 6636259
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/LCD_SP~1/MINI/MINI2/PP-GP0~1.GCO 10145999
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/LCD_SP~1/TAZ6/LCD_SP~1.GCO 3491336
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~2/PP-GP0~1.GCO 1004357
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~3/MINI/M2_PP-~1.GCO 4527773
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~3/MINI/PP-GP0~1.GCO 4527420
Recv: /PRODUC~2/PRINTE~1/LCD_PR~1/MINI_L~4/TAZ6_F~1/PP-GP0~1.GCO 12175930
Recv: /PRODUC~2/PRINTE~1/BED_CLIP/PP-GP0~1.GCO 5378707
Recv: /PRODUC~2/PRINTE~1/BED_CO~1/MINI/PP-GP0~1.GCO 5006769
Recv: /PRODUC~2/PRINTE~1/BED_CO~1/TAZ/PP-GP0~1.GCO 7945967
Recv: /PRODUC~2/PRINTE~1/BELT-C~1/PP-GP0~1.GCO 1591183
Recv: /PRODUC~2/PRINTE~1/BELT-M~1/PP-GP0~1.GCO 17782880
Recv: /PRODUC~2/PRINTE~1/BELT_T~1/M2_PP-~1.GCO 4320816
Recv: /PRODUC~2/PRINTE~1/BELT_T~1/PP-GP0~1.GCO 4318723
Recv: /PRODUC~2/PRINTE~1/BLOWER~1/M2_PP-~1.GCO 3054946
Recv: /PRODUC~2/PRINTE~1/BLOWER~1/PP-GP0~1.GCO 3052480
Recv: /PRODUC~2/PRINTE~1/BUMP_S~1/PP-GP0~1.GCO 4348184
Recv: /PRODUC~2/PRINTE~1/BUMP_S~1/TAZPRI~1/PP-GP0~1.GCO 8252560
Recv: /PRODUC~2/PRINTE~1/DOUBLE~1/MINI2/M2_AS-~1.GCO 15146592
Recv: /PRODUC~2/PRINTE~1/EXTRUD~1/PP-GP0~1.GCO 2988303
Recv: /PRODUC~2/PRINTE~1/EXTRUD~1/MINI2/M2_PP-~1.GCO 2988840
Recv: /PRODUC~2/PRINTE~1/HANDLE/PP-GP0~1.GCO 10080261
Recv: /PRODUC~2/PRINTE~1/RETAIN~1/M2_PP-~1.GCO 1655176
Recv: /PRODUC~2/PRINTE~1/RETAIN~1/PP-GP0~1.GCO 1653080
Recv: /PRODUC~2/PRINTE~1/SPOOL-~1/PP-GP0~1.GCO 4816442
Recv: /PRODUC~2/PRINTE~1/SPOOL-~2/PP-GP0~1.GCO 3409265
Recv: /PRODUC~2/PRINTE~1/SPOOL_~1/PP-GP0~1.GCO 7157246
Recv: /PRODUC~2/PRINTE~1/SPOOL_~1/PP-GP0~2.GCO 9220572
Recv: /PRODUC~2/PRINTE~1/STRAIN~1/PP-GP0~1.GCO 7835002
Recv: /PRODUC~2/PRINTE~1/UNTHRE~1/UNTHRE~1/MINI2/M2_PP-~1.GCO 3856127
Recv: /PRODUC~2/PRINTE~1/UNTHRE~1/UNTHRE~1/PP-GP0~1.GCO 3853124
Recv: /PRODUC~2/PRINTE~1/USB_SU~1/M2_PP-~1.GCO 3788986
Recv: /PRODUC~2/PRINTE~1/USB_SU~1/PP-GP0~1.GCO 3788450
Recv: /PRODUC~2/PRINTE~1/WIPER_~1/PP-GP0~1.GCO 6342912
Recv: /PRODUC~2/PRINTE~1/X_BELT~1/PP-GP0~1.GCO 11322559
Recv: /PRODUC~2/PRINTE~1/X_BELT~1/PP-GP0~2.GCO 11322092
Recv: /PRODUC~2/PRINTE~1/X_BELT~1/M2_PP-~1.GCO 5876216
Recv: /PRODUC~2/PRINTE~1/X_BELT~1/PP-GP0~3.GCO 5873994
Recv: /PRODUC~2/PRINTE~1/X_CARR~1/M2_PP-~1.GCO 3894768
Recv: /PRODUC~2/PRINTE~1/X_CARR~1/PP-GP0~1.GCO 3892463
Recv: /PRODUC~2/PRINTE~1/X_CARR~2/AS-PR0~1.GCO 5184974
Recv: /PRODUC~2/PRINTE~1/X_CARR~2/MINI2/AS-PR0~1.GCO 5185666
Recv: /PRODUC~2/PRINTE~1/X_END_~1/AS-PR0~1.GCO 11816991
Recv: /PRODUC~2/PRINTE~1/X_END_~2/AS-PR0~1.GCO 12487272
Recv: /PRODUC~2/PRINTE~1/Y-IDLER/PP-GP0~1.GCO 8437417
Recv: /PRODUC~2/PRINTE~1/Y-IDLER/MINI2/PP-GP0~1.GCO 8437933
Recv: /PRODUC~2/PRINTE~1/Y-SING~1/AS-PR0~1.GCO 10464815
Recv: /PRODUC~2/PRINTE~1/Y-SING~1/MINI2/M2_AS-~1.GCO 10465415
Recv: /PRODUC~2/PRINTE~1/Z_BELT~1/M2_PP-~1.GCO 2180033
Recv: /PRODUC~2/PRINTE~1/Z_BELT~1/PP-GP0~1.GCO 2177538
Recv: /PRODUC~2/PRINTE~1/Z_BRAK~1/M2_PP-~1.GCO 5662286
Recv: /PRODUC~2/PRINTE~1/Z_BRAK~1/PP-GP0~1.GCO 5659741
Recv: /PRODUC~2/PRINTE~1/Z_LOWE~1/M2_PP-~1.GCO 2388652
Recv: /PRODUC~2/PRINTE~1/Z_LOWE~1/PP-GP0~1.GCO 2386222
Recv: /PRODUC~2/PRINTE~1/Z_LOWE~2/M2_PP-~1.GCO 2387589
Recv: /PRODUC~2/PRINTE~1/Z_LOWE~2/PP-GP0~1.GCO 2385158
Recv: /PRODUC~2/PRINTE~1/Z_UPPE~1/M2_PP-~1.GCO 5861211
Recv: /PRODUC~2/PRINTE~1/Z_UPPE~1/PP-GP0~1.GCO 5858694
Recv: /PRODUC~2/PRINTE~1/Z_UPPE~2/M2_PP-~1.GCO 5160175
Recv: /PRODUC~2/PRINTE~1/Z_UPPE~2/PP-GP0~1.GCO 5157655
Recv: /PRODUC~2/PRINTE~1/STRAIN~2/MINI/PP-GP0~1.GCO 5926634
Recv: /PRODUC~2/PRINTE~1/STRAIN~2/MINI2/PP-GP0~1.GCO 5927119
Recv: /PRODUC~2/PRINTE~1/X_BEAR~1/TEST_X~1.GCO 6733451
Recv: /PRODUC~2/PRINTE~1/X_BEAR~1/AS-PR0~1.GCO 6733451
Recv: /PRODUC~2/PRINTE~1/X_BEAR~1/MINI2/TEST_M~1.GCO 6733988
Recv: /PRODUC~2/PRINTE~1/X_BEAR~1/MINI2/AS-PR0~1.GCO 6733988
Recv: /PRODUC~2/PRINTE~1/Y-MOTO~1/PP-GP0~1.GCO 9864280
Recv: /SAMPLE~1/CALIBR~1/PLA_HS~1.GCO 198948
Recv: /SAMPLE~1/CALIBR~1/NON-PL~1.GCO 515
Recv: /SAMPLE~1/CALIBR~1/OCTO_S~1.GCO 13508
Recv: /SAMPLE~1/CALIBR~1/V2AERO~1.GCO 1688911
Recv: /SAMPLE~1/CALIBR~1/MINI2_~1.GCO 1342
Recv: /SAMPLE~1/CALIBR~1/MINI2_~2.GCO 2088
Recv: /SAMPLE~1/CALIBR~1/HIBISC~1.GCO 6281
Recv: /SAMPLE~1/CALIBR~1/HIBISC~2.GCO 703
Recv: /SAMPLE~1/CALIBR~1/Z-BELT~1.GCO 835
Recv: /SAMPLE~1/CALIBR~1/Z_SHIP~1.GCO 527
Recv: /SOFTWARE/LULZBO~1.GCO 990
Recv: /SOFTWARE/LULZBO~2.GCO 457
Recv: /SOFTWARE/LULZBO~3.GCO 2461
Recv: /SOFTWARE/XLEVEL~1.GCO 575
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~1.GCO 1057
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~2.GCO 457
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~3.GCO 2564
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~4.GCO 1651
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~5.GCO 2498
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~6.GCO 1005
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~7.GCO 808
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~8.GCO 3114
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LULZBO~9.GCO 2888
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C61~7.GCO 2493
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C63~7.GCO 1051
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C68~7.GCO 619
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C5D~7.GCO 1146
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C69~7.GCO 1133
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C6D~7.GCO 626
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C6E~7.GCO 619
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C6F~7.GCO 1294
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C73~7.GCO 626
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C74~7.GCO 1011
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C76~7.GCO 1051
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C7A~7.GCO 718
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C7B~7.GCO 757
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C7C~7.GCO 2361
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C80~7.GCO 2352
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C81~7.GCO 1214
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C82~7.GCO 4269
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C86~7.GCO 5187
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C87~7.GCO 1141
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C88~7.GCO 980
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C8D~7.GCO 3891
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C8E~7.GCO 897
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C8F~7.GCO 3032
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C93~7.GCO 2297
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C94~7.GCO 1327
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C95~7.GCO 5318
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C99~7.GCO 2919
Recv: /SOFTWARE/CURA_L~1/SOURCE/CURA-L~1/RESOUR~1/GCODES/LU0C9A~7.GCO 1474
Changing monitoring state from "Operational" to "Starting"
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
That’s a lot of files on the SD card. If I was troubleshooting this issue, I’d substitute an empty SD card for the one currently in the printer.
kellbot
November 13, 2023, 1:34pm
6
I took out the SD card and now it’s working just fine. Odd that it suddenly popped up, but glad it’s back. Thanks for the help!
