Hi all,
I’m curious to know what you’re using for Axis settings for your Taz 6. I’ve got a profile made up with volume based on the specs for the printer but I’m a bit confused as to what to put for the Axis settings.
Thanks,
Jim
Hi all,
Thanks,
Jim
Hey Jim,
I’m sure by now you’ve figured out values to use for OctoPrint with your Taz 6 printer.
Just in case you’re wanting to know, the axis speeds, extrusion speeds, and other configuration variables can be extracted from your hardware.
Using the Marlin command of M503, which you can send through Cura or your favorite slicer interface.
You can safely run the default speeds or run the specific values bellow.
My unit (which is running the firmware Marlin_TAZ-6.01_Single_v1.0.2.20_01d5281), just uses the default settings of:
X axis: 6000 mm/min
Y axis: 6000 mm/min
Z axis: 200 mm/min
and your build area is:
X : 280
Y : 280
Z : 250
If you did want to set custom values in OctoPrint, you probably don’t want to go faster than:
X axis: 11,500 mm/min (192 mm/sec)
Y axis: 12,500 mm/min (208 mm/sec)
Z axis: 250 mm/min (4 mm/sec)
Here’s the output of my Taz 6, just in case yours varies.
M503
< echo:Steps per unit:
< echo: M92 X100.50 Y100.50 Z1600.00 E816.00
< echo:Maximum feedrates (mm/s):
< echo: M203 X800.00 Y800.00 Z3.00 E40.00
< echo:Maximum Acceleration (mm/s2):
< echo: M201 X9000 Y9000 Z100 E10000
< echo:Acceleration: S=acceleration, T=retract acceleration
< echo: M204 S500.00 T3000.00
< echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
< echo: M205 S0.00 T0.00 B20000 X8.00 Z0.40 E10.00
< echo:Home offset (mm):
< echo: M206 X0.00 Y0.00 Z0.00
< echo:PID settings:
< echo: M301 P28.79 I1.91 D108.51
< echo:Eqn coefficients:
< echo:a: 0.001707 b: -0.000052 d: 2.108326
With the M203 commands set as shown above, even if your gcode tells the printer to move faster, the firmware will not allow it to do so.
