Do you think this mount would work on the Mini2 as well? Did you have to modify any wiring or electronics to make this work? Thx
I built an biqu h2 Mount based on the m175v2, Printables you will need to put code in to reduce the current to the extruder, M907 E120. It also requires a 5v heatbreak fan instead of the 24v that comes with the H2. Verify your wiring in the extruder to be sure it’s connected right out you can kill a driver.
This would work with a mini 2 just fine. You’ll need to build the wiring connector.
Esteps was around 800, and it’s been working well. Using the M175v2 profile in Cura.
