Hi guys, I have my 1st model ready to print (I hope). When I open in Slic3r it looks OK and it is supposedly located in the center of the printing bed.
I generate the G-code, but when I open the G-code file with Proterface, the model is in a corner instead of the center!!!
Does the object print offcenter? Are you referring to the gcode preview window in Pronterface? What are your bed dimensions in Pronterface (Settings > Options > Printer settings > (Width, Depth, Height)).
I don’t know. In Pronterface: Printer (> Printer settings > General > Z offset ) is set to 0 mm, is that what you mean?
Yes
298 x 275 mm
That’s just related to how Pronterface is interpreting the bed dimensions. After your print finishes, try setting the bed dimensions in Pronterface to 100mmx100mm save, close and reopen Pronterface. Then go back and set the bed dimensions back to what you had previously, save and reopen. Then reload the gcode file, it should display correctly.
