Where can I find the molex connector identification part numbers for the lulzbot taz 6 hemera upgrade.
Thanks
Rob Hunter
Rob
I am in the process of building the hemera which part are you talking about if its the 16 way black connector I got mine from RS components but I supply the Mfr part number as well
6 way Molex housing 70450 series
Mfr 22-55-2161
Rs 821-5714
Mfr 16-02-1109 female 24 AWG
RS 821-5629
series 71851
RS 679-4767
Mfr 16-02-0109 Male 24AWG
check before you buy obviously…
Your information is very much appreciated.
The part I am referring to is the inter connection wiring between the Hemera and the main harness which are all Molex.
The Hemera connection is a 20 double row female.
The inter connection on the Hemera side a 20 double row male and the other end is a 16 double row male.
However, my problem is I cannot find any identification information on their casings.
EG; Pitch etc;
Regards,
Rob Hunter
so your talking about the 20 way its a micro fit 3.0
511-0972
link
https://uk.rs-online.com/web/p/pcb-connector-housings/5110972/?relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D626572266C753D656E266D6D3D6D61746368616C6C26706D3D5E2828282872737C5253295B205D3F293F285C647B337D5B5C2D5C735D3F5C647B332C347D5B705061415D3F29297C283235285C647B387D7C5C647B317D5C2D5C647B377D2929292426706F3D3126736E3D592673723D2673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3531312D30393732267374613D3531313039373226&searchHistory={"enabled"%3Atrue}
I didn’t use these they are expensive I think I had to buy 100of the male pins I did away with this and used the 16 way which is what came on the Aeroe 1
I presume you using the converter …
Wow I’m surprised E3D hasn’t made one for Lulzbot.
Looking good there B-Hep
Thanks Just plugged it in and calibrating the Pid and esteps
