TAZ PRO S: STOP BLTouch error (I don't have BLTouch)
My TAZ Pro S does NOT have BLTouch, I did not enable it in Cura, and yet it is still bricking my printer.
I have just (mostly) successfully re-purposed one of the TAZ Pro Dual Extruder heads into a Single Extruder. I wired it according to the diagram below, and so far it has been able to home correctly, can temp correctly, and loaded filament correctly.
However, when I try to initiate any probing, I get ‘Error:!! STOP called because of BLTouch error - restart with M999.’
In a previous post, someone had said that I may need to mirror the wiring too, but how can I heat the extruder correctly with everything else being ‘incorrect?’ heat sink fan is also operational, and so I’m just very confused at this point.
Granted, I did try wiring the 20-pin to the RIGHT extruder spot first and it refused to register the extruder. So then I did switch it over to the LEFT side where then it DID recognize the extruder.
Is it really a mirrored wiring issue? Do I actually need to replace female molex terminals I had de-pinned in order to re-pin them in the correct spots?
I have also tried updating the firmware, but it just keeps listing Firmware version 2.1.3.0.48, even when I say to update the firmware 2-3x now and each time claims the update is ‘complete’ and includes the little happy ‘ding’ noise. Is the firmware also giving me an issue?
I tried checking the g-code and I don’t have the issue where I need to comment a line out (that line doesn’t exist for me in my gcode). Is it a GCODE matter?
Picture of my setup:
There’s separate firmware for the Pro S and Pro S w/BLTouch.
Manually select the Pro S universal firmware from the resources folder and reflash the firmware. It’s possible that CuraLE is selecting the wrong one automatically.
