My Taz 4 (less than a month old) doesn’t expose a Z movement from the onboard LCD. The UI graph (PDF for LCD menu) included in the firmware download lists this in the UI.
I re-flashed to see if that would correct it, but I still can’t see Z in the menus.
Was this feature disabled or removed for a reason?
Ahh, I am selecting the 10mm, as I stopped the print and want to get the head out of the way, moving by 1mm would seem slow. I will check once my next print is done.
